Feedback on NI Community
NI Discussion Forum Upgrade - August 13, 2008
OK, let me try....
Some random picture
OK. We need:
  • Please make the URL the active field. When I open the image dialog, I want to paste right away, without having to first click in the url filed.
  • We need a way to retain the aspect ratio (above I only changed the horizontal resolution, pretty ugly).
  • The dialog should say which one of the numbers is width and which is height.
  • Actually, I would prefer if we could only change the width and the height will be calculated by the system for correct aspect ratio.
Message 11 of 154
(5,511 Views)
Dennis Knutson wrote:
I agree with tst. I really don't like the narrow view as it takes a lot longer to scroll through all of the messages and I've learned to ignore all of the ratings and probably will in the future.
Dennis,
You can go to "My Profile>>> Tagging" and uncheck the enable tagging box to disable the tag cloud and get the wide view back again.
The option to show the tags at the bottom of the sreen broke with the upgrade.
Ben
Message 12 of 154
(5,506 Views)
The img tag links seem to have broke again.
___________________
Try to take over the world!
Message 13 of 154
(5,482 Views)
The new forum does look different.  Probably nicer.
Had another strange behavior while writing a post this morning.  The DELete key was not deleting text.  It now works with this post. And works with other programs.
Just noting it in case someone else observes this behavior.
My personal taste:  I would have moved the tags to above the list of posts (same top area as announcements) and allow the post titles to be wider.
R
Message 14 of 154
(5,467 Views)
I believe the forum forced my "use tag" flag back on again. Did anyone else turn it off yesterday and found it on again this AM?
Ben
Message 15 of 154
(5,462 Views)
I'm sorry that the images are broken again Smiley Sad
And I don't know why our tagging settings were reset again last night.
I am following-up with Lithium now.
Laura
Message 16 of 154
(5,459 Views)
altenbach wrote:
OK. We need:
Thanks for the great list altenbach, I will file all of these suggestions.
Laura
Message 17 of 154
(5,456 Views)
Laura
Images are fixed again.  I'm working to make sure this doesn't happen again.
Thanks for your patience,
Laura
Message 18 of 154
(5,444 Views)
Does the toolbar take a few seconds to draw or is it just me.
Also I clicked on the Emotions button, you now get a samll popup but that takes a few quite a few seconds to fill. ( attached picture as I captured it before it completed.)
In fact it takes even longer when you edit the message
Emotions Popup
Regards
Ray
Message Edited by Ray Farmer on 08-14-2008 09:18 PM
Regards
Ray Farmer
Message 19 of 154
(5,426 Views)
Emotions Popup
Regards
Ray
Confirmed!
And you you start typing before its done fooling around, the text picks up starnge formatting.
Ben
Message 20 of 154
(5,423 Views)
