Feedback on NI Community
NI Discussion Forum Upgrade - May 20, 2009
TonP wrote:
Firefox does this from version 3 upwards, it seems to be some security measure taken to prevent malicous websites to silently load files from your system.
That makes sense.
Now if you use the Code Capture Tool (and you should) the workflow hasn't changed that much. Click the browse button (or the file-field in FF) and paste the name into the browse dialog.
I do.  It is a great tool.  I had just noticed the the extra step was need to be able to paste the filename.
Message 51 of 58
(5,496 Views)
More font size problems:
Have a look at the "top tags" page. The font is gigantic!
Message Edited by altenbach on 05-29-2009 11:43 AM
Message 52 of 58
(5,460 Views)
Laura F. wrote:
Thanks Ravens Fan, I sent that file along to Lithium for their troubleshooting.
Laura
Hi Laura,
I've had the French show up a few times.
Tonight I saw japanese (or is it chinese, who knows?) happen for the first time.  Same two items, the e-mail notification and the attachments link.  Actually replying to this message right now is doing the same thing.
Attached is the html source for the other message.
PS:  Editing this same message caused both of those items to show up properly in English.
Message Edited by Ravens Fan on 05-29-2009 11:29 PM
Message 53 of 58
(5,448 Views)
I also started seeing the Asian fonts. What was different is that I was seeing it every single time I wrote a reply (including this one I'm writing). This was on Monday evening.
Attached is the page source code, though looking at it I'm not sure if it tells you anything.
UPDATE: Just to see if it would make a difference, I cleared the cache and tried another reply on another thread. Didn't make a difference. However, when I went in to edit this message to add this update the font showed in normal English.
Message Edited by smercurio_fc on 06-01-2009 08:58 PM
Message 54 of 58
(5,404 Views)
Replying to your message looks okay to me right now.
I had noticed also, that when editing one of the problem messages, all of the text showed up correctly in English as well
EDIT:
Further information, I tried replying to Laura's message again that gave me a problem before.  No problems now.
Message Edited by Ravens Fan on 06-02-2009 09:12 AM
Message 55 of 58
(5,390 Views)
Thanks Ravens Fan for all of the extra data on the problem.  I have passed your examples along to Lithium.
Laura
Message 56 of 58
(5,379 Views)
I seem to be getting the different language every time now.
Message 57 of 58
(5,368 Views)
I'm still looking for reports of the language issue.  Lithium suspects some parts of the issue may be resolved so if you can post a screenshot when you see the issue, that would be great!
Laura
Message 58 of 58
(5,312 Views)
