Feedback on NI Community
NI Discussion Forum Upgrade - November 2, 2007
Hmmmm.... Interesting...
I'll give that a shot and see what happens.
Thanks for the tip!
Message 151 of 173
(5,203 Views)
smercurio_fc wrote:
Laura,
One thing I've been noticing since the upgrade is that the site response time is much slower than before. I don't know if this is related to the upgrade, or to something else. It's not unusual for me to see 5-10 seconds before I actually get a page. I do not see this with other sites, so I don't believe this is a problem with the network connection I have. It seems to be quite specific to the forums.
Same thing happened to me.  It takes roughly 20 seconds (or more) just to get the window to type the reply.  Same thing logging into the forum.  It seems to take forever.
EDIT:  I checked what Altenbach suggested..  I do not have any subscriptions.  Wow.  I can't imagine having the forum run slower with subs!  Yikes!!!
Message Edited by JoeLabView on 12-10-2007 09:01 PM
Message 152 of 173
(5,199 Views)
Check the "Subscribed Threads" tab. The default operation of the forums (I believe) is to add a thread to that category when you respond to a message. All that I've done so far is to change the option altenbach mentioned to "None", and I'm just seeing how things work. I periodically clean out the Subscribed Threads, but am not doing it yet to only change one thing at a time.
Message 153 of 173
(5,187 Views)
Hi All,
Keep me updated about whether this suggestion helps.  I also feel that performance is slower than usual, though it's very hard to pinpoint.  We are taking steps to actively monitor performance and Lithium is also aware of the issue.
Laura
Message 154 of 173
(5,191 Views)
Today's speed is normal.  1/2 sec to get a page.  no time to sip coffee..  😉
Message 155 of 173
(5,182 Views)
After deleting about 1800 subscriptions, I can report that the performance is much better now.
Ben
Message 156 of 173
(5,176 Views)
The "strange" speed changes also affect other areas for me, such as the HW section.  Yesterday, it took forever to browse thru some PXI cards.  Now it's ok.  I'll blame my PC.. 😉
Message 157 of 173
(5,163 Views)
it seems there are still some bugs :
http://forums.ni.com/ni/board/message?board.id=BreakPoint&view=by_date_ascending&message.id=4681#M46...
... And here's where I keep assorted lengths of wires...
Message 158 of 173
(5,164 Views)
What I have noticed that the Select Board control can take the value of the last board you posted from. This is particular to the boards where you are forced to make a search, as as the labview board. ( see my previous post 72 of this thread).
Regards
Ray Farmer
Regards
Ray Farmer
Message 159 of 173
(5,155 Views)
Hi Ray,
Now I get what you meant in this post.
I never even noticed I was posting to Breakpoint.  I "assumed" that the question would be posted in the active forum where you did the search, as it used to do in the past..
As I was saying earlier, it might explain the surge of posts in the wrong forums..  Look at me!  Deuh.. I posted in the wrong forum..
other.Ray
Message 160 of 173
(5,144 Views)
