01-23-2007 08:07 AM
01-23-2007 08:32 AM
NOOOOoooooooooooooooooooooo. (Grabs head with both hands...)
The last thing I need is another thread floated to the top of the board. I think a better solution would simply be to rename the New Message button to New Topic and make it much more prominent (e.g. make it another color).
01-23-2007 08:40 AM
Or, better yet, New Question.
01-23-2007 08:58 AM
I think one of the problems, is if you do a search then Post a Question via the search page. The Selected Forum displays the one you were last on which is not always the forum you require to post too.
Maybe the Selected Forum control should be made such that you have to select a forum, with the control displaying some text like "select one" before it will accept a the Post Message.
Ray.
01-23-2007 11:04 AM - edited 01-23-2007 11:04 AM
Message Edited by altenbach on 01-23-2007 09:04 AM
01-23-2007 06:57 PM
@BrianPack wrote:
I remember my first time coming to the NI forums (it was also my first time using any sort of web forum,) and it was hard to know what to do and where to post (I didn't read the help of course...Im an engineer 🙂 )
01-24-2007 12:39 AM
01-24-2007 01:32 AM
@TonP wrote:
Another thing, Dell uses the same forum engine and has a pane on the left side showing the different forums. Might be something?
But it should be something that can be turned off.
I just gave the Dell forums a quick look and in my opinion that pane takes up way too much valuable area.
Also, I think the colors NI chose are much better, but maybe that's just because I got used to them.
One thing that Dell did that I do like is adding that arrow to the reply buttons, making them easier to see. Personally, I think a button should appear as a button, not an image or a piece of text which only gets highlighted when you hover over it. In the same way, a link should be underlined or should make it perfectly clear in the text that you need to click there.
01-24-2007 12:38 PM
I vote for New Question, which would do an automatic search First. Does 2 things, return found links or allows to post new thread if nothing was found..
(or will I read this when i continue reading the posts??) 😮
01-24-2007 04:32 PM
