 altenbach
			altenbach
			02-01-2014 10:20 AM - edited 02-01-2014 10:20 AM
forums.ni.com has been very inconsistent for more than a day with slow and incomplete page loads.
The ping times can be in the hundreds of milliseconds and packetloss is up to 50%.
Here is a ping output from just now:
> ping -t forums.ni.com
Pinging ni.lithium.com [208.74.204.114] with 32 bytes of data:
Reply from 208.74.204.114: bytes=32 time=112ms TTL=247
Request timed out.
Request timed out.
Request timed out.
Reply from 208.74.204.114: bytes=32 time=184ms TTL=247
Reply from 208.74.204.114: bytes=32 time=206ms TTL=247
Request timed out.
Reply from 208.74.204.114: bytes=32 time=19ms TTL=247
Reply from 208.74.204.114: bytes=32 time=20ms TTL=247
Reply from 208.74.204.114: bytes=32 time=21ms TTL=247
Ping statistics for 208.74.204.114:
 Packets: Sent = 12, Received = 8, Lost = 4 (33% loss),
Approximate round trip times in milli-seconds:
 Minimum = 19ms, Maximum = 206ms, Average = 86ms
The main bottleneck seems to be hop #9 (lithiumtechinc-3.border3.sje.pnap.net [74.201.87.122]).
What's the problem? Maintenance? Technical difficulties? DOS attack?
02-21-2014 01:13 PM - edited 02-21-2014 01:17 PM
The problem is back again since last night. Forum is almost unusable! 32% packet loss is way too much.
Is anyone looking into this?
02-21-2014 02:09 PM
02-23-2014 01:36 PM
Still the same. Am I really the only one? Seems to affect ALL lithium forums (e.g. verizon, lenovo, etc.). All seem to stall at the Lithium Border router.
Discounting the possibility that Lithum network engineers don't know what they are doing, my best bet is that they are under DOS attack. Maybe they pissed off one too many powerful spammer cartels. 😄
 RavensFan
			RavensFan
			02-23-2014 01:46 PM
I'm seeing it as well. And a couple times over the past several days. Pinging forums.ni.com seemed quick enough. The initial recognition of the page loading is happening fairly quickly, but it is a long running progress bar while waiting for the rest of the page to load so that anything is readable.
02-23-2014 02:03 PM
currently I see >50% packet loss. See you all later.
Reply from 208.74.204.114: bytes=32 time=126ms TTL=247
Request timed out.
Reply from 208.74.204.114: bytes=32 time=128ms TTL=247
Request timed out.
Request timed out.
Request timed out.
Reply from 208.74.204.114: bytes=32 time=125ms TTL=247
Request timed out.
Request timed out.
Reply from 208.74.204.114: bytes=32 time=124ms TTL=247
Request timed out.
Request timed out.
 Packets: Sent = 15, Received = 7, Lost = 8 (53% loss)
 Ray.R
			Ray.R
			03-17-2014 07:23 AM
I thought the problem was at my end, because I observed the same performance issues in February and early March.
Thanks for posting Christian.
