Feedback on NI Community
Problem entering Emotions
has anyone else had problems entering Emotions from the Popup.
Sometimes I press the emoticons.gif button an the toolbar and select the desired face only nothing gets inserted into the message. In the end I have to close the panel and reopen it again to try again. usually it works the second time.
My using IE 7.0.5730.13
Regards
Ray
Regards
Ray Farmer
Message 1 of 14
(8,145 Views)
I see that quite frequently.  It seems like it doesn't work when the popup doesn't load completely.  There is an indication of when the popup truly finishes loading.  First you see all the icons load, (and that takes way too long, and 3/4 of them are useless).  Then there is a slight pause.  Then the size of the window seems to jump slightly larger.  Once that happens then the icon will usually insert okay.  (I won't guarantee it, but generally.)  If I don't see that final jump in the size of the window, then I can almost guarantee that the emoticon won't insert when I click on it.
Overall, the original emoticon dialog was far better.
Message 2 of 14
(8,144 Views)
I use Firefox and I pretty much have to display the window twice about 95% of the time. Yeah, real improvement. NOT.
Message 3 of 14
(8,139 Views)
I have learnt to live with it. I usually drag the emotions and place it in the message. works everytime
Message 4 of 14
(8,129 Views)
Same here.
Ben
Message 5 of 14
(8,122 Views)
I accept.
Message 6 of 14
(8,117 Views)
Totally agree with this thread.  Inserting emoticons is a real pain..
Although for some, it may be a real joy to see less of them...  being abused...  by someone like me..
Message 7 of 14
(8,112 Views)
Your image is not visible
It is now
Message Edited by muks on 10-20-2009 05:48 PM
Message 8 of 14
(8,108 Views)
Ravens Fan,
You right about the jump at the end. Smiley Very Happy
Ray
Regards
Ray Farmer
Message 9 of 14
(8,105 Views)
Lol Smiley Very Happy Join my name after you Smiley Wink
Message 10 of 14
(8,104 Views)
