Feedback on NI Community
Problems uploading a ZIP file
I also get the error "file conteents don't match file type" when trying to attach a VI to a post. I'm using LabView 2012, Windows 7 OS, and FireFox 21.0
Message 21 of 88
(7,360 Views)
Test uploading different VI versions (Windows 7)
 For me no problem to upload old versions
Message 22 of 88
(7,342 Views)
Upload an empty file as a VI.
Only works if file is not empty, but works if there is only one byte in the file. So not a valid VI file.
Message 23 of 88
(7,337 Views)
This issue still seems to be unresolved.
I tried attaching a .png file to a message which was a code snippet from the Code Capture Tool.  It gave the same error message.
Message 24 of 88
(7,307 Views)
Hi Jordan,
Any update on this?
I am still having problems.  I tried to attach a .png file today and receive the error.  (Straight up image, not even a snippet.)
But I was able to resave it as a jpeg and it uploaded okay.
What did Lithium do a few weeks ago to break things?
Message 25 of 88
(7,282 Views)
Still not fixed.
Tried attaching a snippet as a .png file and still got the "The contents of the attachment doesn't match its file type"error.
Message 26 of 88
(7,282 Views)
Me too having problems as can be seen here (and in several other threads)!
I have to rename VIs to "*-vi" instead of usual "*.vi" to be able to upload them. When will Lithium fix this problem?
(Using FF22.0, Java disabled)
Message 27 of 88
(7,272 Views)
I just started seeing this today. When I attempt to upload a VI, using Firefox, I get "The contents of the attachment doesn't match its file type." However, I did successfully upload a PNG from Firefox, and in Internet Explorer I don't see this error at all even when attaching a VI.
Message 28 of 88
(7,245 Views)
I also got the "content does not match file type" message when uploading a VI just now in FF 22 (and in IETab). The upload worked from IE 10.
___________________
Try to take over the world!
Message 29 of 88
(7,215 Views)
tst,
Were you trying to upload a VI as well?
Jordan
Message 30 of 88
(7,200 Views)
