Feedback on NI Community
Separate forums
Something I find annoying is trying to search through the Labview forum to find answers regarding real-time issues. If you click [RT], all you get is "rt" in front of your search criteria. Then if I search for something, I get a whole bunch of responses from different forums across the map. It would be nice to be able to break it down better, like either separate forums or a choice in the advanced search to only search the RT portion.
Thanks for hard work in keeping things updated in the forums.
(6,075 Views)
I agree that this can be confusing, as those links that appear just below the "LabVIEW" forum name are just quick search shortcuts. When you do a search it just lists the forums, and there is no "LabVIEW - RT" forum. The best that you can do is limit it to "LabVIEW".
There was a similar discussion about subforums some time ago
(6,071 Views)
