Feedback on NI Community
Some threads continuously refresh
... and makes it impossible to add Tags.
It does not happen on all threads.  I just happened to catch another one this morning, where I wanted to add a tag.
Check out this thread:  http://forums.ni.com/ni/board/message?board.id=180&message.id=3706
(7,226 Views)
Accepted by Ray.R
Dear Joe,
In profile settings, under "Turn on Live Edits and Updates", just disable the check mark if already checked. Hope this helps.
Mathan
(7,219 Views)
Thanks Mathan,
It worked 😄
Curious:  how did you know?
(7,210 Views)
I CAN GIVE KUDOS!!!
Wow..  That was my problem!!  Thanks and Kudos to you Mathan!  😄
(7,206 Views)
Hi Ray -
Glad to hear that Kudos are working now!  I thought you had one computer where Kudos worked and one where it did not so I assumed it was a problem with a particular computer.  Sounds like that was an incorrect assumption on my part and I apologize for not catching that earlier when you reported it.  Have fun giving out kudos!
Laura
(7,197 Views)
Thanks Laura.
Don't worry about it since my suspicions were the firewall at this location.  I would never have thought that a setting could cause the issue.
At least if others have a similar problem we can suggest a solution.  🙂
Have fun!
RayR
(7,192 Views)
Ray.R wrote:
Thanks Mathan,
It worked 😄
Glad it worked. Smiley Happy
Actually i pirated this idea from Laura. Smiley Wink See her post (#60). Hope Laura will never blame me for this. Smiley Sad
(7,181 Views)
