Feedback on NI Community
Test thread
This is just a test.
___________________
Try to take over the world!
(6,364 Views)
Had this been an actual message, you would have been instructed in one of the many finer points of LabVIEW.
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(6,354 Views)
This is a test reply to the first post.
(Later, I will find out if it actually worked...It is difficult to switch from dataflow based posts to text based posts :))
(6,346 Views)
The actual test begins now.
Testing, testing.
One, two three...
Results: PASS.
___________________
(6,342 Views)
Which property did you use to get the green color for the result "PASS"?
I keep looking for the property node in your text....  😉
(6,324 Views)
