Feedback on NI Community
Top Tags are disappeared
Whenever I scroll down from top to bottom the Top Tags section gets disappeared
But when I get the mouse on it, the behaviour is normal
TOP TAGS
Message 1 of 9
(8,182 Views)
Vish, I hate to be the one to tell you, but nobody else can see pictures you attach.  You're just providing a local link to your desktop.
Message 2 of 9
(8,163 Views)
Really?... but I can see them in 2 different PCs... even the attached files are also cannot be seen?
Message 3 of 9
(8,160 Views)
I can't see the embedded images, but I can see the attached jpg's.
Message 4 of 9
(8,157 Views)
Ok got it.
will correct that. Thanks JeffOverton
Message 5 of 9
(8,150 Views)
The source for your embedded images is  "C:\Documents and Settings\Administrator\Desktop\Vish\NI\Disappeared.PNG"  Only you have access to that file.Smiley Wink
If you want to embed the images.
1.  Post the message with the images attached.  (Which you did.)
2.  Click the editmessage link under the Options drop down to edit the message.  (You have to do this within 10 minutes of first posting.)
3.  Right click on the attachments and select properties.  Copy the address which will point to a location on the NI website (not your hard drive.)
      In your case, one is http://forums.ni.com/attachments/ni/130/4399/2/Appeared.PNG
4.  Go to the spot in the message where you want to insert the image.  Click the image button.
5.  Paste the address into the pop up dialog.
6.  Repeat for all of the images you want to embed.
Now when you post, you and everyone else will be able to see the images rather than just you.
Here is disappeared as linked to your attachment:
And appeared:
Message Edited by Ravens Fan on 04-08-2008 09:16 PM
Message 6 of 9
(8,123 Views)
Ok, thanks every one. This is what happens when you use an operating system with italian language and the keyboard is in english... Smiley Mad
Message 7 of 9
(8,111 Views)
To the original problem, I agree there is a redrawing bug in the tag area. I noticed the same behavior over the last few weeks.
Could be a bug in a specific browser or could be sloppy coding. I'm seeing this in IE7 with all updates applied. Anyone seen this in other browsers?
Message 8 of 9
(8,097 Views)
I have not seen this issue in firefox, and a quick try hasn't reproduced it in IE7 for me.  I will send along the screenshots to our forum vendor.
Thanks for your feedback!
Laura
Web Support & Operations
Message 9 of 9
(8,037 Views)
