04-08-2008 12:12 PM
04-08-2008 03:07 PM
04-08-2008 03:18 PM
04-08-2008 03:25 PM
04-08-2008 03:31 PM
04-08-2008 08:12 PM - edited 04-08-2008 08:16 PM
The source for your embedded images is "C:\Documents and Settings\Administrator\Desktop\Vish\NI\Disappeared.PNG" Only you have access to that file.![]()
If you want to embed the images.
1. Post the message with the images attached. (Which you did.)
2. Click the editmessage link under the Options drop down to edit the message. (You have to do this within 10 minutes of first posting.)
3. Right click on the attachments and select properties. Copy the address which will point to a location on the NI website (not your hard drive.)
In your case, one is http://forums.ni.com/attachments/ni/130/4399/2/Appeared.PNG
4. Go to the spot in the message where you want to insert the image. Click the image button.
5. Paste the address into the pop up dialog.
6. Repeat for all of the images you want to embed.
Now when you post, you and everyone else will be able to see the images rather than just you.
Here is disappeared as linked to your attachment:
And appeared:
04-09-2008 03:00 AM
04-09-2008 09:59 AM
To the original problem, I agree there is a redrawing bug in the tag area. I noticed the same behavior over the last few weeks.
Could be a bug in a specific browser or could be sloppy coding. I'm seeing this in IE7 with all updates applied. Anyone seen this in other browsers?
04-14-2008 05:10 PM
