03-21-2017 10:13 AM
Today I received one of these automated emails from the NI forum. What I find a bit confusing is that my answer has been considered a solution two years ago....
Hello Wolfgang,
A reply to a topic you are following has been accepted as a solution.
Topic: Including complex.h fails
Author: hihahors
Date: 14-05-2015 09:18 AM
Solved! Go to Solution.
03-21-2017 11:13 AM
Hello Wolfgang,
Would you be able to tell us the timestamp of when you received this email?
Karina Barles
NI Community Support
03-21-2017 11:51 AM
Hello Karina,
here are some more details:
Return-Path: <webmaster@ni.com>
Received: from smtp.lithium.com ([208.74.204.5])
Received: from sjc1papp96.sj.lithium.com (sjc1papp96.sj.lithium.com [10.21.110.44])
by smtp.lithium.com (Postfix) with ESMTP id 0BE6940763
Date: Tue, 21 Mar 2017 08:02:25 -0700 (PDT)
03-21-2017 02:24 PM
Thank you for the information, did you also get a notification in Community in regards to this?
Thanks!
03-21-2017 04:09 PM - edited 03-21-2017 04:13 PM
em..., I am sorry but I do not understand... what is a notification in Community? You mean, in the Notification Feed? No... there is no respective entry
03-22-2017 08:29 PM
Hello Wolfgang,
We have made some research and it seems like the author of the original post made two updates, it seems like he unmarked the solution and marked it again, reason why you received the email.
Please let us know if you require any additional assistance.
Thanks!
Karina Barles
03-23-2017 12:22 AM
Hello Karina,
thanks, this sounds plausible - but then I would have expected that the forum (Solution Accepted by topic author...) also shows the more recent date of the accepted solution, not the previous one...
03-23-2017 09:50 AM
Hi Wolfgang -
Yes, that would normally be the case. However, there is a bug affecting accepted solutions from before August 27, 2015 wherein the date will always display as August 27, 2015. We believe that this is why you are still seeing this date on the post.
Lili
03-23-2017 10:32 AM
Ah ![]()
Thanks!
