Feedback on NI Community
Weird IE7 error message
At home on IE7.  Went do www.ni.com.  Clicked on Discussion forums (my usual way of getting in.)
It came up with this error message.  Link in address bar is https://sine.ni.com/apps/utf8/niup.ni
Shield icon
There is a problem with this website's security certificate.
The security certificate presented by this website has expired or is not yet valid.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
We recommend that you close this webpage and do not continue to this website.
Recommended iconClick here to close this webpage.
Not recommended iconContinue to this website (not recommended).
More information More information
  • If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting.
  • When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com.
  • If you choose to ignore this error and continue, do not enter private information into the website.
  • For more information, see "Certificate Errors" in Internet Explorer Help.
    (6,838 Views)
    I posted the message about IE7 error.  I submitted it by copying and pasting from the IE7 screen with the error.  The message got cut off in the message, and I couldn't select edit out of the drop down menu.  Something weird in the html of the error message I posted?
    Here is the text as plain text.
         More information
    (6,834 Views)
    I'm getting the same message.
    (6,826 Views)
    Odd that I can reply but not see any of the previous replies.
    Ben
    (6,805 Views)
