Feedback on NI Community
What is wong with my signature?
For some reason, when I post in the forums, after my signiture it leaves 6 or 7 lines of empty spaces.
I've checked in my profile for carriage returns and there is nothing.
It should just be "Cory K" without all of the space underneath
Cory K
Message 1 of 8
(7,927 Views)
It appears that the signature is embedded in a <div> tag with the height set to 180. The actual <div> tag looks like this:
<div style="width: 100%; height: 180; overflow: hidden;">
I've never used a signature, but the signature creation box is supposed to accept HTML, so maybe you can just set the HTML yourself directly.
Hmmm.... let's see what happens when I use a signature....
Message 2 of 8
(7,915 Views)
Yup, looks like that's what it defaults to, as the same thing happened when I simply put in the text "This is a signature". I got a bunch of blank space at the bottom.
I've since removed the signature, so that's why you can't see it now. Smiley Wink
Message 3 of 8
(7,911 Views)
Accepted by Cory_K
Update: It appears that whatever you put it it gets enveloped by the <div> tag I mentioned above. So even if you put in your own <div> tag, you'll get another one around with the height:180 property. Smiley Sad
Message 4 of 8
(7,907 Views)
I'll just get rid of it then. Oh well
Cory K
Message 5 of 8
(7,899 Views)
I think perhaps this should give a heads up to Laura. There may be a good reason for the <div> tag, but perhaps we can ease off a bit on the forced height? Hmmm? Smiley Wink
Message 6 of 8
(7,887 Views)
So I had to increase the space allocated for signatures a while back after an upgrade because some signatures were large and were starting to get cutoff.  The extra space below signatures is more apparent in Firefox than in IE7.  I have not recently revisited the issue to see what happens if I decrease the space so I'll add that to my issues to research list Smiley Happy
Laura
Web Support & Operations
Message 7 of 8
(7,863 Views)
I'm using Google Chrome, and it is VERY apparent  :smileyvery-happy:
Cory K
Message 8 of 8
(7,855 Views)
