‎01-28-2011 03:51 PM
First time I noticed this tab was yesterday. Curious
Solved! Go to Solution.
‎01-28-2011 04:05 PM
We're not using that functionality. I think it turned on when I enabled the Kudos count sort the other day. I'll see if it can be decoupled and turned off.
Laura
‎01-28-2011 05:16 PM
Looking at Lith-admins kudoes it looks like the feature left in Oct 2008
‎01-28-2011 05:30 PM
These are the carryover kudos from the old rating system. They are not tied to a donor, so some of those could be even from me. 😄
‎01-31-2011 09:50 AM
Experts typically have a higher Kudo "weight" which means that they can give more than one Kudo at a time. We haven't been using that feature, but in order to get the ability to sort by Kudos in the Recent Kudos Received widget (requested in another thread), I had to enable Kudos weight, which made that Experts tab show up. Sigh...
‎02-01-2011 06:46 AM
Why the sigh?
After we finish the conversation about the "long tail" we may be able to put that feature to good use.
thinking out loud....
If the long tail reveals our experts then they can use Kudos to help bring the good post to the top.
Ben
