Feedback on NI Community
Who's been messing with the formatting?
@Ray Farmer wrote:
has this
always been like this.
I get that often most of the time with XP/IE8.  I'll have to check with Firefox..
Message 51 of 97
(5,184 Views)
@Laura F. wrote:
Ravens Fan - I see the bad formatting issue with compatibility on.  Is that the case for you or is it really with compatibility off?
Edit: Also I just double-checked and the autosave problems happen with compatibility on, so if you see the same behavior as me hopefully you can use IE8 with compatibility off for now.
Also, I was expected the autosave bug to be fixed soon so I will double-check on that.
Laura
It really is with compatibility mode off.
Compatibility mode on, problem with autosave, formatting of the message grid is fine.
Compatibility mode off,  no problem with autosave, but the formatting of the message grid had problems with some lines droppin lower than they should.  Sometimes more, sometimes less.  Sometimes they will completely drop into the messages below.
Message 52 of 97
(5,172 Views)
@Laura F. wrote:
Thank you all for your replies. This experience must be very frustrating and I apologize. I currently have different issues open for the different items. Combined they make the forum experience quite unpleasant in IE8 so I will be attempting to raise the severity of these issues.
Thank you again for your patience.
Laura
Actually, this morning it's on Firefox. I.e., it looks like the stylesheet isn't being "gotten". No changes were made to my system. Windows XP, SP3. Firefox 3.6.13. Posting this on IE because I can actually see what I'm doing.
Message 53 of 97
(5,160 Views)
Still happening? I don't see any problems... I'm going to find someone with XP to check.
Laura
Message 54 of 97
(5,155 Views)
Ok, found someone with XP and we don't see the issue here. Please report back when you can.
Message 55 of 97
(5,152 Views)
Yes, I was still seeing the issue this morning. For most of the morning. At least until 10 AM (Central Time). It's gone now. Note: I am referring to the problem I saw in my first post. Others have been bringing up other problems in this thread, so I wanted to make sure you knew which one I was referring to.
Message 56 of 97
(5,150 Views)
I'm seeing the problem from the first posting on my work laptop, using Firefox 3.6.13, WinXP Pro. I'm not seeing it with my personal laptop WIn7 Firefox 3.6.13. Did the clear cookies, cache, etc. to no avail. It was working last night at 1930EST not working at 0800EST.  On work computer it looks ok in I.E. 6 (hey, they said they were going upgrade our I.E. browsers a year ago!)  Weird!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 57 of 97
(5,140 Views)
Ha, ha, refreshed screen on my laptop and it too is displaying the "non formatted" columns as in the original post. Am posting this on the work laptop in IE, which showed the page correctly but has messed up this entry screen, with the reply buttons stretching across 1/3 of the page and this text entry screen showing roughly 20 chars across. Argh!!!
Putnam
LabVIEW Champion
Message 58 of 97
(5,137 Views)
The next time you see formatting issues in Firefox, can you please grab a screenshot? I've seen the issues in IE and need to know what's going on in Firefox. The other thing that was requested is to grab the html source of the page when you see it messed up and paste it into a text file.
Laura
Message 59 of 97
(5,127 Views)
@Ray.R wrote:
@Ray Farmer wrote:
has this
This particular issue should have been fixed last night. Please let me know if you still see it.
Message 60 of 97
(5,126 Views)
