Feedback on NI Community
can't fill in text in idea exchange "Post a Comment"
Like others over here: http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/Can-t-reply-to-a-post-on-LabVIEW-forum/td-p...
Since two days, I can't type in anything in the "Post a Comment" field in the idea exchange in Firefox 29.0.1. The LabVIEW forum works ok, it's just the idea exchange. Posting a new message is also no problem.
There is no cursor. I tried loggin in and out, and also tried switching betwee Preview, HTML and Rich Text.
IE still works, but it takes minutes to load, and then seconds after each character.
Message 1 of 10
(7,836 Views)
Also in chrome it does not work at all now in the same way (blank comment window, not able to type at all). I cleared all browser stuff, but it did not fix it.
Message 2 of 10
(7,827 Views)
Not related to firefox i guess. Works good for me.
Message 3 of 10
(7,822 Views)
This is a problem... People having this problem can't reply!
Message 4 of 10
(7,817 Views)
never mind. In this forum posting is no problem. At least not for me. Just the idea exchange.
Message 5 of 10
(7,812 Views)
I did find some sort of solution.
When I press F5, the page refreshes. Then, for a short moment, I can type in some text. Then it disappears. But when I switch to HTML view, I can actually edit the message (in HTML).
So it seems to be a problem in the Rich Text part.
Message 6 of 10
(7,800 Views)
for some reason:
<textarea style="visibility: hidden:" class="lia-form-tiny-mce-editor-input lia-message-editor" id="tinyMceEditor" name="tinyMceEditor">jfkjm jhjghrjj</textarea>
this element and other elements, like the buttons, are hidden. When I change "hidden:" to "none" I can edit normally (but without the buttons..
Message 7 of 10
(7,792 Views)
Text only in IE.  no links, smileys, pictures. no text format...........  Spell check broke......
Message 8 of 10
(7,776 Views)
Hey guys,
This is an issue with the comment editor. It should be resolved in tonight's maintenance window and the spell check functionality should be resolved as well.
Jordan
Message 9 of 10
(7,773 Views)
Jordan,
It's OK now! Thanks,
Wiebe.
Message 10 of 10
(7,748 Views)
