Feedback on NI Community
does the forum corrupt old zip files?
Message 1 of 14
(8,253 Views)
There are other mysterous things going on:
I created a post with a snippet.
After posting the image shows fine in the post. Some minutes later the image has vanished, only the name of the snippet is shown.
Ok, I created a second post for that snippet: same procedure of vanishing image after some minutes.
See this thread.
Again some "trial and error" feature test at Lithium?
Message 2 of 14
(8,229 Views)
It seems like it might be fixed now.  The zip file Christian talked about, I also got errors when trying to pull the files out of it yesterday, but today I can do it just fine.  And the snippet images seem to show up now in the message thread Gerd is referencing.  (Though I was not on the forums before now to see if they were ever missing for me.)
Message 3 of 14
(8,223 Views)
Hi Raven,
for me the image in message #2 is still missing, while the image in message #3 is (right) now visible too…
Message 4 of 14
(8,220 Views)
Both images show for me.
Message 5 of 14
(8,217 Views)
One hour later: Now I can see both pictures too…
Message 6 of 14
(8,214 Views)
Same problem again:
I posted a message with a picture and verified it can be seen. Now some minutes later I only see the picture's filename! Here
What's going on here?
Edit:
When I look at the HTML source of the message and try to open the link to the picture I get a FireFox error message saying "the image can't be displayed because it contains errors" (rough translation from German)…
Message 7 of 14
(8,192 Views)
I see it at the moment.  For reference, I'm using IE9.
Message 8 of 14
(8,179 Views)
Hi RavensFan,
I can't see it right now using FF32.0.1.
Digging something deeper:
The link to the image in the HTML source is:
http://forums.ni.com/t5/image/serverpage/image-id/154449i5A5115086F2A7331/image-size/original?v=mpbl...
 Here FF refuses to load.
When I copy that link to a new tab and "clean" it up to
 FF can load the image without problems…
Can NI/Lithium verify this annoyance?
Message 9 of 14
(8,175 Views)
next morning: the image is back (atleast for me)! And is is still found under the very same link…
Mysterious…
Message 10 of 14
(8,163 Views)
