Feedback on NI Community
looking for NI Requirements Gateway Forum - or am i impatiently? -no text
Message 1 of 8
(7,867 Views)
TimoS -
We do not currently have a forum for the NI Requirements Gateway.  My recommendation is to post questions in the forums related to the other NI products you are using with the NI Requirements Gateway - ie. LabVIEW, LabWindows/CVI, TestStand, and MATRIXx.
Thanks!
Molly K.
Web Support & Operations Manager
Message 2 of 8
(7,839 Views)
Hi Molly,
I want to use RG with DOORS and TestStand or LabVIEW.
My problem is the exchange between DOORS and RG
(Did NI take over Telelogics in the last days ?)
regards
Timo
Message 3 of 8
(7,837 Views)
Timo,
I would suggest posting in the TestStand Forum.  I monitor that forum and will be able to answer your questions on NI Requirements Gateway.
Allen P.
NI
Message 4 of 8
(7,819 Views)
I'm currently evaluating Requirement Gateway and I'd find it really useful if there was a seperate forum on this product.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 5 of 8
(7,691 Views)
Hi Allen,
I am currently testing Requirements Gateway. As it seems it does not find any controls placed on a tab control to see if it is covered or not.
Is there any reason not searching for controls placed on tab controls?
We have VIs iterating over complex Front Panel structures to find all controls. Maybe we can add this functionality to NI RG LabVIEW interface.
Is there anyone can help in this?
Andras
Message 6 of 8
(7,173 Views)
Did you write a description under (i think) "Description and Tips" that has a keyword which can be found in the requirements document?  Something that when looking at the VI documentation, or respecially the controls description so that it can be traked to the requirements document.
example:  (timing response within an Event Structure.. the VI description would include a line like the one below)
This control satisfieds the REQ_SoftwareResponseRequirement
Message 7 of 8
(7,028 Views)
Requirements Gateway won't recognize covering statements in Tab controls nor in individual fields of a cluster. This has been fed back to N.I.
Message 8 of 8
(6,931 Views)
