FieldPoint Family
16-bit Analog Output Module
I currently have a system with two cFP-AI-100 FieldPoint A/D Modules that are accompanied by a cFP-AO-210 Module. They are both 12-bit, but I’m looking to upgrade my system’s resolution with a cFP-AI-110 with 16-bits. Is there a 16-bit AO module that I would need to get as well?
(5,360 Views)
HiCCSU-Student,
First of all, I would recommend that if you are in the process of upgrading, that you consider the cRIO platform. It will be much more reliable, future-proof, and capable. However, I understand if a complete upgrade is not possible.
Regarding your question about needing a 16-bit AO module, are you asking if you must have a 16 bit AO module to go with the AI module? Or are you looking for a 16 bit AO module?
Also, out of curiosity, what will you be using the modules for? Or why are you upgrading? If you are looking to upgrade the AO module, the extra context might help us make suggestions.
(5,326 Views)
Thank you for your timely response, but I have since obtained an answer to my question.
(5,294 Views)
