FieldPoint Family
banks offline or read only access
while saving configuration file of FP-2010 a warning appears
banks offline or with read only access
screen shot of warning is also attached
wht should i do
mazhar
Message Edited by mazhar.ali on 07-17-2008 09:17 AM
Message 1 of 8
(11,825 Views)
Hi!
   It is quite common to see this message, it usually comes up when you are using MAX, configuring some remote controller, while other controllers are no longer on-line on the network.
   In your case, I suppose you are able to see the module, the only problem is that when you save (tools -->fieldPoint --> save) your .iak file, MAX is saving it on the PC, while it is unable to save files on remote cFP controller.  So you won't have cFP properly configured.
   I would try first to save several times (it can be done to unstable LAN), if problem remains, check "field point access control" tab, to set permissions to you PC.  What's this tab like in your current configuration?
graziano
Message Edited by Graziano on 07-18-2008 01:36 AM
Message 2 of 8
(11,808 Views)
hi Graziano
thnx for ur intrest
i hav tried a lot of time but problem still exist
according to status led yhe fp is configured and there is no error with fp-2010
i attached one more screen shot
regards
mazhar
Message 3 of 8
(11,800 Views)
I see,
   I don't know, but what I find strange is that your "add" button seems to be disabled, just have a look at my MAX:
Are you able to perform an FTP file transfer from PC to cFP?
graziano
Message Edited by Graziano on 07-18-2008 09:26 AM
Message Edited by Graziano on 07-18-2008 09:27 AM
Message 4 of 8
(11,797 Views)
Hi!
   Sorry for this silly question, but... has your cFP module an IP address within the subnet mask?
graziano
Message 5 of 8
(11,757 Views)
thanx Graziano
for ur time n intrest
i have fixed my problem
regards
mazhar
Message 6 of 8
(11,691 Views)
I know this is pretty old, but I am trying to resolve an issue with a fieldpoint system and I am getting this error. Can anyone tell what was done to resolve this.
Message 7 of 8
(7,235 Views)
For future reference, it's best to create a new post. More people will see a new post than a reply in an old thread. But are you able to connect to your controller?
Message 8 of 8
(7,222 Views)
