FieldPoint Family
Add serial ports on cFP
I have a cFP-2110 already installed. If i need an additional serial port on it, what could i do (other than buying a whole new cFP)? For example for cRIO there's the NI 9870 module, but for cFP...
(6,381 Views)
you could use a NI ENET-232 or ENET-485 serial device in order to add serial ports to your cFP, as explained in the following tutorials:
Adding Networked Serial Ports to Your (Compact) FieldPoint or PXI System
Can I Use the ENET-232 or ENET-485 in LabVIEW Real-Time?
Serena
(6,363 Views)
