FieldPoint Family
Build Errors VI, OK in Edit Mode
I get the following error message when doing a build preview.
The VI runs fine in edit mode.
Unable to generate preview. The following files have links to help files that are invalid. Open the files and fix the help links.
C:\National Instruments\LabVIEW 8.0\vi.lib\FieldPoint\Polymorphic Read.llb\FP Read (Float Array).vi
<Call Chain>Error 7 occurred at ABAPI Check Help FIles.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File.vi -> EBEP_Invoke_Build_Engine_Preview.vi -> EBUIP_Build_Rule_Editor.vi -> EBUIP_Item_OnDoProperties.vi -> EBUIP_Item_OnDoProperties.vi.ProxyCaller
(6,866 Views)
Hi Allan,
Could you please list which options you are selecting when building a source distribution? Under "Distribution Settings" category, could you try checking the "Disconnect type definitions and remove unuses polymorphic VI instances" option and see if that helps with the build process?
Also I suggest Mass Compiling your VIs (Tools -> Advanced -> Mass Compile) before creating a source distribution. If these do not help, could you attach your project with all the VIs it contains here?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(6,844 Views)
Adnan
Thanks for the help.  I may well be missing the point but I was trying to build an executable not a source distribution.
Allan E (uncertain novice)
(6,840 Views)
Sorry about that, for some reason I assumed you are building a source distribution. Try to mass compile, and let me know what happens.
Adnan Zafar
(6,837 Views)
Problem solved I think, at least the error messages have gone away, upgraded fieldpoint to 5.01 and a mass compile did that trick.
thanks
 Allan
(6,832 Views)
