FieldPoint Family
Calibrate FP-TC-120
Is there a way to go about calibrating the FP-TC-120 and the FP-AIO-610 without purchasing software or sending them back to NI??
Thanks in advance.
Bobby
LabVIEW 2016 - Windows 7
CLAD
(3,154 Views)
Hi Bobby-
It's pretty unlikely that you will be able to calibrate your FieldPoint modules with equipment you already have in your lab. FieldPoint calibration requires the FP-TB-CAL terminal block and Calibration Executive software. You may also need to acquire a different controller as the FP-1000 is required. Unless you already have a lot of this equipment on hand, your best option may be to send your modules to NI for calibration.
Hopefully this helps-
Tom W
(3,135 Views)
