FieldPoint Family
Replacing file automatically
I am trying to run an html generating report automatically every day but each time it runs I would like it to replace the existing file.  Currently it asks 'do you want to replace...?' each time.
Thank you in advance.
I will attach my vi also.
Laura
(3,681 Views)
Laura,
In the 'Save Report to File.vi' there's a sub Vi for opening the file called 'Open/Create/Replace File.vi.'  This VI is popping up the "replace?" dialog.  You can suppress this dialog by wiring a FALSE to the 'advisory dialog?' input.
You probably want to make a copy of the 'Save Report to File.vi' and then make this change and use the VI, rather than changing the original.
-Khalid
(3,671 Views)
Thank you for your help.  Sorry I took so long to thank you - just got excited at my project working then got carried away!  Anyway thanks.
(3,653 Views)
Smiley Happy
(3,642 Views)
