FieldPoint Family
FP 2000 Publish data
Hello,NOW  I  use FP 2000 and AI module . I use GSM/GPRS modem(I can use AT command to cintrol it) but I want  to publish data from sensor to my PC (FP 2000 stand alone).You have any Idea for this
(3,286 Views)
Hi woot-
Are you asking about an application similar to the one being discussed in this thread?  If not, can you please elaborate on what type of data you are trying to publish?  Are you trying to read values from your AI module directly to your PC or are you just inquiring about a generic way to pass information between two instances of LabVIEW (i.e. the controller and your PC) once the data is already read by an embedded program on the controller?
If you are trying to read values directly from the inputs I would advise you to use the NI FieldPoint driver as it has built-in functions to read and write values to a FieldPoint bank.  The driver's interface through your modem may be somewhat problematic, however, as it is primarily designed to interface via ethernet communications where an IP and/or hostname can be assigned to the controller.  Is this situation possible with your modem?  As I mentioned in my other thread, a better option may be to interface a wireless router with your modem and then use a wireless NIC to use the native ethernet communications protocol that the FieldPoint driver employs.
Thanks-
Tom W
(3,278 Views)
