FieldPoint Family
Can I use the Run VI method on a Compact FieldPoint?
I am trying to run a VI on a Compact FieldPoint 2020 module that invokes vi's.  When I run it on my desktop it runs fine, but when I upload it to the cFP, it does not.  Can you use the Run VI method on a cFP similar to the one in the example I attached to this message?
Message Edited by Synap on 03-30-2006 01:51 PM
(3,371 Views)
I found my answer!
Turns out that the cFP CAN run the Run VI method, it's just that it's file serching abilities are not as robust as the full desktop version.  Make sure you upload the vi (still looking for an automatic way to do this) and make the file path point to it explicitly (i.e. "C:\NI-RT\LABVIEW DATA\File.vi" if you happened to upload it there).
(3,365 Views)
