FieldPoint Family
I have some problem in configuring compact field point 2100
Hi
I have problem to configure my CFP 2100,.
My network is in domain, In measurement and automation explore by double clicking on remote system it will not showing the CFP connected on port so what i do.
so how to configure please tell me.
Regard
Santosh P Jaiswal
(3,295 Views)
Santosh,
You will have to manually assign a static IP addres to your cFP controller.  I.e., the controller will not get an IP address automatically via DHCP.  Also, it has to be on the same sub-node to be seen/browsed from MAX.
Hope this gives you some ideas.
-Khalid
(3,289 Views)
