FieldPoint Family
Citadel Database
Hello friends,
I have 3 doubts on citadel database.
1. what is the size of the database? where can i find the database size? iam using arund 500 shared variables in my prject and i have enabled logging data, alarms and events...what will be the size of the database?
2. I have 3 machines as workstations where i installed only the runtime files. i am not able to access the database stored in my server from my wortkstations. Is there any other things i have to do to view the database ?
3. Attach database option in MAX. Consider machine 1 has 100 datas and machine 2 has 110 datas, what will happen if i attach machine 2 database with machine 1 database?
Regards
John
-John Theodore
Certified LabVIEW Architect, Certified TestStand Architect
(6,683 Views)
1. This overview document has a section of the size of citadel data.
Logging Data with National Instruments Citadel
2. You can view a citadel database from a remote computer. Check out this document on how its done.
How Do I View a Citadel Database on a Remote Computer from MAX?
3. Check out this tutorial
Merging Two Databases Using the Historical Data Viewer in MAX for the LabVIEW DSC Module
For future knowledge, you can post this on the LabVIEW forum, and not Field Point.
(6,666 Views)
