FieldPoint Family
how do you replace a defective C-drive
The c-drive on a cFP-2120 appeared to be corrupted.  We replaced it with a 512 Mb flash.  Can't get the fimware loaded and working again
(6,875 Views)
lewb,
Did you try re-formating it?
(6,865 Views)
reformatted and downloded image from another 2120 but get corrupted firmware error.
(6,860 Views)
lewb,
Probably time to contact NI.  Just curious, how old is this cFP?
(6,856 Views)
Lewb-
Your cFP-2120 has 2 flash memory drives.  There is the c: drive and the d: drive.  The c: drive is where the OS is stored and you as the user do not have access to (you must open the controller case which will void your warranty).  The d: drive is the flash drive that you have access to on top of the controller.  This can only be used for storage.  Therefore if the c: drive memory has been corrupt, the best way to fix it is go to www.ni.com/contact and “Request Support”.  Give us a call and we can RMA it for you.
What version of the NI-FieldPoint driver do you currently have on your computer?  The most recent version is 6.0.6.  Please make sure you have this version installed.
NI-FieldPoint
https://www.ni.com/en/support/downloads/drivers/download.ni-fieldpoint.html
What version of the firmware do you have on your controller?  You can potentially upgrade the firmware on your controller which may fix this issue.
Mike S
NI AE
(6,831 Views)
Thanks, I used a 128 Mb card and it seems to work fine.
(6,829 Views)
