I have been running a cFP-2110 with labview 8.0 for about year without any problems. Recently I changed the IP address on the cFP-2110 and since then I continue to get the error 32812 FP write.VI. I have searched the message board about the error and tried several of the solutions without correcting the problem. I went as far as deleting the remote system in MAX and then rebuilding the system with a new name and did have some success. After rebuilding the system and then creating a new project and building a simple test vi the system worked error. However, when I close the project and only have the VI open, I get the same error 32812 FP write.VI. If I reopen the project and run the test VI it runs error free. Before changing the IP address and on the two other compact fieldpoint system I have in the lab I don't have this problem and have never had to keep the project explorer window open to run a VI.
On the system that gives me the error, when I have the project open the test VI is listed on the Project Explorer window under the My computer icon (just above dependencies and build Specifications). However I on my other computer that is running LabView 8.5 and running two additional compact fieldpoint systems the VI's are not listed on the project explorer page. I feel like the error has a simple fix that I am overlooking something but I can't figure out what I'm doing wrong or how just changing the IP address created the error. Any help resolving the problem would be much appreciated.
Thank you
Danny
Danny
