FieldPoint Family
Error 32812: specified tag name not found
I've just started using LabView 7.1 (under Windows) with a Compact Fieldpoint and developed a small data acq. test program. I've built an install and installed the program on another PC. I've also installed MAX onto the target PC and loaded up the Fieldpoint iak file into MAX. Everything worked fine the first time I did this and my program communicated with the Fieldpoint. Now, I've just installed a new version of my program and I'm getting an error 32812 specified tag name not found when I use the FP Read.vi.
Any ideas what is wrong? I presume that my iak file has the wrong tags in it? But it's the same one saved from my development PC! I did notice a slight difference in the versions of MAX, my development PC has
3.1.1.3003 and the target PC has 3.1.0.3021. If this is the problem where do I find an updated install for MAX
Many thanks
Mike
(4,450 Views)
(4,365 Views)
I continue to have the same error 32812 has there been any resolution to this problem? I've been told it relates to the tag name which must be "FieldPonit" however this does not work consistently.
(4,362 Views)
Hello Mike-g
This is a common error. Checkout the following Knowledge base for more information on how to deal with it:
http://digital.ni.com/public.nsf/websearch/02EB73D02715981A8625682B00774F8F?OpenDocument.
Hope it helps...
(4,346 Views)
