FieldPoint Family
FP-1000 giving error.help needed plz!
I was working on a Field Point with Configuration FP-1000,FP-110, FP200,FP-401.I am using a labview program to run the machine.It was working fine before but it now gives error "initialization to the field point server failed-connection to remote device timed out-possible causes(1) corrupted Configuration file (2)the call back to the device failed check open.VI"
I have no idea what went wrong.I had checked for the serial port RS232 but dint find any problem.I would greatly appreciate if someone can help me.
(3,139 Views)
Hi newtoFP-
It sounds like you are having software or driver problems that are preventing your FieldPoint controller from communicating properly. I would first try to verify connectivity.
If you are seeing connectivity but not proper operation I would suggest re-entering your device configurations as the configuration (.iak) file may have been corrupted.
If you're unable to connect I would try to verify that the serial port is not being reserved by another application and that the cable is firmly seated in both connections and the device is powered up before you attempt to access it. If you can test the setup on another computer and with a different serial cable we might be able to isolate the problem better to the FieldPoint system or the computer itself.
Another good option to try would be to update both your FieldPoint drivers for the host PC and the firmware for the controller itself. The most current version of the FieldPoint driver is available at this location
If these methods are unsuccessful, please reply with any error codes you see in communication and the exact error text from the error popup.
Thanks-
Message Edited by Tom W. on 06-03-2005 01:43 PM
Tom W
(3,130 Views)
