FieldPoint Family
FP-AO-C420 doesnot update value in FP explorer, although we get iak operation was successful.
FP-AO-C420 doesnot update value in FP explorer, although we get message "iak operation was successful."
We are using it with FP-2010.
(3,463 Views)
My computer was set for comma (,) for decimal places. I set it back to period (.) and everything is ok. Thanks to Aaron G. I found this solution from his answer to a similar problem posted by Jorg on 2/10/03.
(3,463 Views)
What version of FieldPoint Explorer or NI-FP are you using? If you had the wrong decimal symbol, it should have reported an out of range error.
Aaron
LabVIEW Champion, CLA, CPI
(3,463 Views)
I was using 3.0.1. Later I upgraded to 3.0.2 as suggested by NI tech support. Yes, it did report out of range error, but once, at the very first attempt to write. After that it kept quite, no error and no updates. So I thought whatever be the problem related to range is no more there. Otherwise it should give error for every attempt to write.
Aarif
(3,463 Views)
