FieldPoint Family
FP_CreateTagIOPoint
I'm using LabWindows/CVI and 2 of FP-TC-120 and 1 FP-AI-100.
In that case, the following source code is right? Please advice me.
All variables, buffers and IOHandles for FP-TC-01, FP-TC-02 and FP-AI-01 are independant.
Initialize
FP_Open
FP_CreateTagIOPoint for FP-TC-01
FP_CreateTagIOPoint for FP-TC-02
FP_CreateTagIOPoint for FP-AI-01
FP_Advise for 3 FP for FP-TC-01
FP_Advise for 3 FP for FP-TC-02
FP_Advise for 3 FP for FP-AI-01
advice_loop
FP_ReadCache for FP-TC-01
FP_ReadCache for FP-TC-02
FP_ReadCache for FP-AI-01
Thanks You.
(3,877 Views)
I have checked through your source code flow. It appears to me that you are doing this correctly. To be certain that you are using the function calls correctly, I would take a look at the LabWindows CVI examples in the ...MeasurementStudio\CVI\samples\FieldPoint directory.
Good Luck,
Mike
NI
(3,877 Views)
Hi. Gentleman.
I try to find MessurementStudio/CVI/samples/fieldpoint directory.
But the samples treat only 8channel. that means just 1 Module(8Channel) of Fieldpoint.
I want to need the samples which treat 2 or more Fieldpoint module.
Anyway, Thank you so much for your answer.
If find good samples, Please advice me.
Thank You.
(3,877 Views)
