‎05-27-2009 05:56 PM
‎05-28-2009 01:03 PM
‎05-28-2009 04:04 PM
‎05-29-2009 09:50 AM
Based on the fact that another one of the FP-AI-V10Bs does work in the other slots, hooked up the same way, it appears that there is a hardware malfunction with the offset FP-AI-V10B. You aren't incorporating a scale with this specific module, are you? When you observe the incoming signal, are you observing it in LabVIEW or MAX?
If you are not using a scale and the incorrect signal is being viewed in MAX, I would suggest calling in to support for an RMA: http://sine.ni.com/apps/utf8/niae_asc.main?lang=US
