FieldPoint Family
FieldPoint Write error error code -34101, when reading directly from the IO (cFP PWM-520)
Problem/question:
We are trying to read from a PWM-520, but as you can see we get an -34101 error.
We do not understand what the reason is ... the VIs we use are NI and we read directly from the hardware.
If the same same IO point is configured as a Share Variable and deployed on the cFP target, we can both read/write without problems.
But we wish to read directly from the IO to increase performance of the realtime system.
Attached is VIs and pictures.
Hope you can help us solving this problem.
Mark & Søren
About us:
Since 1991 we have been developing LabVIEW applications for Haldor Topsoes Research & Development division. Currently the LabVIEW team consists of 4-5 people, with a total of more that 30 years of LabVIEW programming experience.
Software:
We are now developing applications using LabVIEW 7.1 and 8.2 Professional Developer Measurement Suite. We are building applications for Automation, data acquisition and advanced data treatment. We have a total of more than 200 builded LabVIEW applications running 24/7 in the laboratories.
Hardware:
In a company, with more that 65 years of history, hardware found in R&D is both of newer and old date. The newest test unit is using NI hardware; two cFP-2120 and two cFP-1800 with a total of more that 300 IO's.
Kind regards
Mark & Søren
Message Edited by mzl on 10-17-2006 11:57 AM
Message Edited by mzl on 10-17-2006 11:58 AM
Message 1 of 1
(4,193 Views)
