I have several questions related to use FP-AI-110 and FP-AO-200 to control Mass flow controler. Mass flow controller has a 15-pin D connector. Both the input and output are 4-20 mA. Firstly I connected only one MFC to channel 0 of FP-AI-110 and FP-AO-200.
(1)Iin and COM of FP-AI-110 was connected to two current output pins of MFC.
(2)Iout and COM of FP-AO-200 was connected to two current setpoint pins of MFC.
(3)Vsus and COM terminals of FP-AO-200 of which V and C terminal connected to external power supply of 24 V was connected to 2 pins of MFC D connector that needs 15-28 Vdc power supply according to MFC specification.
Now the problem is the reading of FP-AI-110 is 0 although the N2 gas was passing through the MFC. Fur
thermore, there is one error of code 33180 with FP-AO-200(The amount of data provided does not match the number of data items required or the number of channels to be addressed:FP Write.VI). Even though I regulate the output of FP-AO-200(setpoint for MFC), the gas flow rate of MFC didn't change.
Does FP-AO-200 control only by current output? Thanks a lot.
