FieldPoint Family
Fieldpoint Hardware Drivers that are compatible with LV 8.5 and Windows Vista
I trying to develop in LabVIEW for some Fieldpoint hardware. I was going to download the hardware drivers from NI, but only see drivers that are compatible with Windows XP and LV 8.2
Or, am I just misinterpreting this?
Also, are there any potential conflicts with me developing on Vista, if my end-user, is uding another OS?
Daddy-O
One should welcome adversity as an opportunity to excel.
(6,029 Views)
Hi Daddy-O,
Thank you for contacting National Instruments.  This is a little misleading, and unfortunately the driver you are looking for is currently not directly searchable.  In order to use your FieldPoint hardware with LabVIEW 8.5 and Windows Vista, you will need the FieldPoint 6.0 driver.  This can be found within the disk that is distributed with new FieldPoint hardware, and any Device Drivers CD from August 2007 forward.  Unfortunately, a standalone installer is not available for this driver, and if you do not have a hard copy of the Device Drivers, you can download this here.  From this installer, you should be able to select FieldPoint 6.0 and install this software.
I hope this helps!  Let me know if there is anything else I can clarify.  Have a great day!
Jason W.
Applications Engineer
(6,012 Views)
