FieldPoint Family
Fieldpoint OPC server freezes up
A Honeywell DaVinci system communicates with Fieldpoint OPC server. After working properly for hours, the analog outputs would not respond to write updates from DaVinci system. I tried to use FactorySoft OPC client to connect to the Fieldpoint OPC server and also could not manipulate the analog outputs. However, I could still change the outputs using the Fieldpoint explorer. Please advise how to fix this problem.
(3,257 Views)
What version of the Fieldpoint OPC server are you using? There was a memory leak issue in 3.0.2.177 (I think that was the rev.). Is the opc server memory usage increasing?
See also:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=137&HOID=5065000000050000000DF60000&HTHREAD=000062989&UCATEGORY_0=_18_%24_17_&UCATEGORY_S=0
Matt
(3,256 Views)
