02-24-2006 03:13 AM
02-25-2006 02:53 AM
The DO module does not output pulses by default - it just outputs a On/Off state. You can, however, force it to generate pulses by toggling the output very fast from your code. Not sure if this is what you want to do. If you want the hardware itself to output the pulses, you shold check out the PWM module.
-Khalid
