FieldPoint Family
Real-time web publishing using Snapshot setting
I am trying to set up a simple data monitoring application on a cFP-2020 using LV7.1. The application runs great and I can view the front panel remotely using the web server feature and the "embedded" option.  I need to be able to use either the Monitor or Snapshot mode to view the screen on a non-LV machine, but the front panel image never appears.  I was able to find one reference in the KB that Real-Time targets running LV6.1 can only serve "Embedded" views. Is this still the case with LV7.1? LV8?
Steve
(3,736 Views)
Hi Steve,
I was able to verify it is still the case that RT targets can only serve 'Embedded' views. I used LabVIEW 8.0 for this verification. Have a great day!
Prashanth
(3,723 Views)
Thank you Prashanth.
Steve
(3,710 Views)
