02-21-2005 09:18 AM
02-22-2005
10:00 PM
- last edited on
11-11-2025
10:25 AM
by
Content Cleaner
Hello Soares,
You might want to first upgrade your FieldPoint driver to the latest by going here.
02-23-2005 08:19 AM
02-24-2005
05:49 PM
- last edited on
05-22-2025
03:19 PM
by
Content Cleaner
Hello Soares,
Since you are using Win 98, you will need to install NI-FieldPoint 4.0.1 instead.
You can also upgrade the software [not the firmware]. All the links are available at the link shown above. However, I would advise you to try just upgrading the driver to 4.0.1 and if the problem persist, then you can upgrade the software to the latest version that can work on Win 98. It is under the "Run-Time" section of the page.
