FieldPoint Family
How do you remove the Startup.exe from FieldPoint?
I know how to install a vi into the Startup.exe on a FieldPoint, but how do you remove it/unistall it?
(3,485 Views)
You can delete a startup.exe from a fieldpoint unit using an ftp program if you first rename the startup.exe to something else. Rename it to 'temp', then delete 'temp'.
Matt
(3,485 Views)
Jordan,
Doing a quick search through the Knowledge Bases I found the following:
http://digital.ni.com/public.nsf/websearch/7BE1A1F4363C0465862569A6000319F9?OpenDocument
You can then FTP in and delete the executable.
Ames
(3,485 Views)
