Home
Community
Discussion Forums
Most Active Hardware Boards
FieldPoint Family
Topic
FieldPoint Family
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do you remove the Startup.exe from FieldPoint?
ObeJuan
Member
09-01-2004
02:47 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I know how to install a vi into the Startup.exe on a FieldPoint, but how do you remove it/unistall it?
0
Kudos
Message
1
of 3
(3,480 Views)
Reply
Re: How do you remove the Startup.exe from FieldPoint?
Matthew_William
s
Active Participant
09-01-2004
04:16 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can delete a startup.exe from a fieldpoint unit using an ftp program if you first rename the startup.exe to something else. Rename it to 'temp', then delete 'temp'.
Matt
0
Kudos
Message
2
of 3
(3,480 Views)
Reply
Ames
Member
09-01-2004
05:45 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Jordan,
Doing a quick search through the Knowledge Bases I found the following:
http://digital.ni.com/public.nsf/websearch/7BE1A1F4363C0465862569A6000319F9?OpenDocument
You can then FTP in and delete the executable.
Ames
0
Kudos
Message
3
of 3
(3,480 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
