FieldPoint Family
How to correct cFPAI112 offset of 3mV (+-60mV range) when Vin is shorted to COM?
I am seeing a 3mV offset on my cFP-AI-112 when Vin is shorted to COM on the +-60mV range.  How can the offset be adjusted?
(6,051 Views)
Hi Dave,
Sounds like your cFP-AI-112 might need calibration. You can check out NI's Calibration Services here.
  • How old is your cFP-AI-112?
  • Is the offset present on all channels?
  • What happens when you select a different input range?
Joshua B.
(6,036 Views)
