FieldPoint Family
Where can I get the correct drivers and modules needed for FP-2000
Hi
I am using LabVIEW 7.1 and I'm trying to get on line to an FP-2000 Ethernet controller module,
from reading the data sheets I need to have fieldpoint installed and also the labVIEW realtime module, does any one know the correct versions I should be using here?? I am assuming 7.1?
Also where can I get a download of these? Can't seem to find these on the NI website all I find is the release notes.
Kevin
(6,074 Views)
Hello Kevin,
To use LabVIEW with the FP-2000 you require the Fieldpoint driver software.  I have included a link below to download the latest version
https://www.ni.com/en/support/downloads/drivers/download.ni-fieldpoint.html
LabVIEW Real-time 7.1 is not available online for download.  The NI website currently has the latest version of LabVIEW 2009 and LabVIEW Real-time 2009.  If you plan to use these later version, you require Fieldpoint 6.0.5.
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(6,054 Views)
