FieldPoint Family
Moving cfp1808 to new network, do I have to modify the IAK file or update the fieldpoint tags in the code?
First time moving existing gear to a new network (.exe via App Builder).  Familiar with the build process, but looking for guidance on accommodating the new IP setttings.  No problem changing the hardware, do I need to modify the .iak file and if so does that mean I need to update the fieldpoint tags in the code?
Other issues I need to be aware of?
Many thanks.
-Heyla
(6,608 Views)
Hi Lapster,
Sorry about the delayed response, but you can look at this document on Applying FieldPoint IAK Settings to a FieldPoint Real-Time Controller for some information on IAK files, and for your questions on IP settings, take a look at this document on Linking an IAK File to a Compact FieldPoint with a Different IP Address.
I hope this helps.
Stephen S.
Applications Engineering
(6,571 Views)
Thanks for the reply, Stephen.  In the interim I spoke with tech support and received the following instructions which did the trick:
save IAK file from development PC
connect cFP-180x (with new IP address) to new network
find devices in MAX
create new FieldPoint Item
open IAK file
save IAK file with same name
apply the configuration to the cFP-180x bank
start a fresh LabVIEW session
-Heyla
(6,551 Views)
Glad to hear that you got this worked out, and thanks for posting what worked for you on the forums so others can see.
Stephen S.
(6,535 Views)
