FieldPoint Family
Showing results forย
Search instead forย
Did you mean:ย
How to query a FieldPoint FP-2010 from Linux
I want to query and control a FieldPoint Module FP-2010 (and some connected modules like FP-AI-110 ...) from Linux. Referring to Document ID 181A6Q8U this should be possible somehow. Unfortunally I didn't find an example VI from which I can learn what to do. I just want to read a channel from a FP-AI-110 or write a value to a FP-DO-403. Are there any tutorials that show me what I must do under Linux?
Thanks in advance for your help,
Armin Herzer
Hochschule Ravensburg-Weingarten
University of Applied Sciences
Germany
(3,538 Views)
Here you can find information concerning this topic:
http://digital.ni.com/public.nsf/websearch/C87C7D6E4EDA4348862565DA005E7359?OpenDocument
So you have to use a Windows machine to write and download your RT-Application to the (C)Fieldpoint Controller. You have to implement a TCP/IP Communication on the fieldpoint-side. Via TCP/IP you can communicate from linux with the fieldpoint system.ยด
But to make it clear: You will need a windows machine with LabView and LabVIEW RT to program and download the RT-application to your fieldpoint system. You can not do thsi from a linux machine.
(3,531 Views)
